What are these metal washers called please?
20 Nov 2012
Devon
Hello
I've been struggling to find large thin metal washers like the one in the photo.
(I lost the originals for a Keter plastic shed that was taken down, and Keter customer service are unresponsive after 3 months)
Does anyone know what they are called please?
I've looked up serrated / locking / shakeproof / toothed washers, and can find none with this edging, and without the correct name type, I'm really stuck with a search.
(The outer measurement is 33mm and the inner is 27mm - they are 0.5mm thickness )
Thank you in advance
I guess you found the ones that are £3 each on ebay? I'd just try something similar to see if that works
as above, I would have thought anything similar would do unless there is a specific reason for that design!
some say 'toothed lock washers' should be replaced after every use (i don't, but guess nasa woud on a space rocket)
A plastic shed...so its just to stop the bolt undoing as it vibrates in the wind ... so any sprung washer will do...
As a skilled engineer I always change any form of lock washer after I've removed the nut/bolt. They do in the aircraft industry and woe betide anyone found not doing so.
You can't really compare the aviation industry to a plastic shed.
