Hi everyone
I am hoping that someone can help me with this problem that I am having with my Boiler.
The Boiler is a Vaillant ecoTEC plus 832.
The Boiler works fine in providing Hot Water but for some reason are the Radiators not warming up at all throughout the entire House when I turn the heating on.
There are no fault codes on the display and there have been instances when the desired temperature that I set it for gets reached but the Radiators are still not warming up.
I checked the temp settings and had it ip to 65 and even tried 75 but still no luck.
Then did I try to turn the comfi mode off on the water settings which also did not help.
The Water pressure is also in the right place.
If there is anything that I may be able to do without calling someone out then I would really appreciate some help and advice.
Wali110
Wali110
