Hello, after a little advice if possible. We moved into a 1930s semi a few months the ago. The sunroom (built ten years ago) has a small leak in the corner. We are assuming this is the roof. It is low pitched (from googling so far I think the pitch is too low for the tiles).
However I'm reluctant to retile or change the pitch for the tiniest of leaks in one corner. Money is a tad tight at the moment and we have loads of other renovations going on. The leak happens in heavy rain only. I've attached photos. Hopefully these help illustrate the issue. You'll see from the photos that in the corner where the leak is we have water marking on the brickwork. Could this be water escaping between the gutter and fascia? Would this cause an internal leak? Any advice of what we can do is greatly appreciated. Thank you.
