This is probably somewhat passe by now, but regarding brakes, this is my technique......
With the caliper bracket off and in the vice, I pop off the anti rattle shims / clips and investigate the metal beneath. If there is any rust there (nearly always is) its back down to bare metal by either wire brushing or careful filing. Rust expands at a phenomenal rate and any expansion there will grip the pads firmer than intentioned.
The caliper bracket is a drop forging and I've no idea what the metal constituents are - some rust like hell, others hardly mark and the make of vehicle doesn't seem to matter.
This done, its on with the ceramic grease and replace the rattle shims after wire brushing them clean. More ceramic grease on the pad edges and backs and then carefully reassembled, using silicone grease on the pad sliders and rubber boots if necessary.
I shift the bleed nipple and coat that too.
Even more ceramic grease is applied to the cleaned hub, and of course where the alloy wheel faces onto the disc.
Personally I think that coppaslip has had its day regarding braking systems.
John
John
