Dishwashers: When is it time to send them to the farm.....?
1 Dec 2021
Ireland
My Neff dishwasher has stopped heating water. Relay is ok, no dry joints so the heat pump seems to be the suspect.
The unit is 11 years old.
I've given it CPR on a number of occasions (not the most reliable unit I've ever had tbh) and i feel this is the final nail in its coffin.
A new pump is likely to cost me €100 (ebay + delivery+exchange+customs, blah blah
Now, €100 is a long way from €600 to replace it, but, it also needs new seals, the door is worn, and it goes into a coma every now and then.
I wish parts were more accessible and cheaper. A new door seal and heat pump is +£200 from Neff. Mad prices which stops many from repairing them.
Would you fix this?
11 years is not bad surely? (My last one lasted 8 years)
Although i like to avoid throwing things away, there comes a Return on investment - at 11 years old - what else is likely to go wrong - so is it worth chucking 200+ at it - if its likely to fail in near future
Which maybe another part failing , and actually die
on the otherhand -
when we moved, we have a very old Dishwasher , which was my mother-in-laws , Bosch and I had a new Bosch , which i fitted into my old kitchen purchased in 2008 and nothing like the quality
we refurbed this new kitchen in 2018 - and we looked at dishwashers to replace the mother-in-law one , and the cheaper ones £400-600 - seemed really poor quality ,when we reached about £1200 , we just made the old one fit
Our Hotpoint lasted just over 20 years. Like you, I’d done a few repairs over the years - dispenser tray, a couple of arms, filter etc and it also had an occasional leak from the door seal. When it started getting temperamental we cut our losses and bought another Hotpoint. Much better cleaning, quieter, uses less water and cheaper to run.
New heating element, check old one resistance at - 20 ohms.
There is a YT vid of some bod doing exactly this.
Apparently, you need to do an insulation test to properly check the unit. I don't have one so I'm snookered there!
A simple continuity test with a multimeter set to resistance will tell you if it is open circuit, no need for insulation tester in your case.
