Of course we agree on the principle. The reason that at least some parts of the house will get colder as soon as the extractor is turned on is because the previously-heated air (in at least some parts of the house) will be 'diluted' by incoming cold air.So we agree on the principle of dilution.
As I said, of course it will. However, that is the very issue underlying the reason for this discussion - that turning on the extractor will result in the need to expend ('costly') energy to compensate for the effects of the extraction.First of all - the heating system will more than easily make up for any loss ...
That's the bit which I don't understand. If you leave the extractor running, and have no heating running to compensate for the heat loss, then, eventually, (some) heat from the house will continue to be lost until the inside temp is equal to the outside temp. The rate of heat loss will gradually reduce, as the previously-heated air in the house gets progressively more and more diluted by incoming cold air (i.e. the air in the house gets colder) but, if one waited long enough (with no heating switched on), the indoor temp would theoretically eventually fall to roughly the outdoor temp.... and secondly dilution is a very major factor, in not extracting as much heat as you would seem to assume.
As above, basic physics theory indicates that there will be "a difference" (in cost of heating and/or temp inside parts of house). However, you may be saying that difference might not be enough for you to "notice". Although, as below, I somehow doubt this, it's possible that you are right that the difference may not be "all that large" - but with fuel prices as they are, some people would be concerned about any increase in energy usage, even if not all that large - let's face it, we're seeing people getting concerned even about the energy cost of leaving their TVs on 'standby'.I would not expect any noticeable difference in the cost of running my heating system, or the indoor temperature whether my bathroom fan ran continuously or not.
Extract fans are relatively tiny, compared to the air volume in a building, which is why the need to be located close to what ever they are intended to extract.
Approved Doc F suggests minimum extraction rates of 15 L/s (54 m³/h) for a
It much worse with kitchens, since Approved Doc F then suggests minimum extraction rates of 30-60 L/s (108 - 216 m³/h). That means that, at the upper end of that guidance range, about 77% of the air in the house would be extracted in 1 hour, and, if it were run continuously, something like 18.5 times the volume of volume of air in the house every day.
I would therefore suggest that extraction rates (at least 'minimum recommended' ones) are far from as trivial in comparison with house volumes as you appear to be suggesting.
Don't forget that, regardless of what is being extracted ('diluted' or not, moist or not) if, say 54 m³/h (of something) is being extracted, then 54 m³/h of cold air will enter the house from outside to replace it.
Edit: typo corrected
