In fact, if you had a "TT" earth in your house (i.e. achieved with a local earth rod in the ground, rather than an 'earth' provided by your supplier) (which many people, like me, do have), then the boiler would presumably work - and I can't see what would be different from that if you were using your own generator and an earth rod.
I'm not sure what MCB/RCD you are talking about, but I can't think of any particular issue. In fact, if you used a generator without providing some sort of 'earth' connection in its output (e.g. by connecting the generator's neutral to the 'earth' conductor in its output socket (or even in the plug), then any RCD you had in the generator supply would not work as intended/required.John - Thought about an earth rod but not sure how that affects the MCB and RCD trip.
I agree. In fact, even when it were 'unplugged' the boiler would almost certainly still be connected to your house earth, by virtue of metal piping connecting it to other things (like main bonding, immersion heaters etc.)...... My guess is it would work if I made a permanent connection to the house earth and used the generator to supply live and neutral.
Very probably true.True - maybe the manufacturers tech people just have a general answer that assumes a generator out put will be so unstable, it would damage the boiler? So the always answer is NO.
I don't know whether it is different with the new-fangled technologies, but with my ancient boiler, both the ignition and 'flame failure' (which, in my case, is just an old-fashioned thermocouple) work fine when I plug it into my genny, and that remains true even if (undesirable though that may be, for other reasons), the output of the genny is 'floating'.
Yes, I realise that - but does that differ materially from my ('old-fangled') thermocouple which uses the metallic outer of the thermocouple 'tube' (which is in electrical continuity with the "casing/metal of the boiler") as part of the electrical path?They now use an ionisation probe to detect the flame, which allows a tiny current to flow through the flame, to the casing/metal of the boiler. No current, no flame - or no earth to the boiler.
Your isolation arrangements appear to contravene the Electricity Act.Has worked fine using main consumer unit and a mains isolator to prevent backflow.
I have, with 2 different generators. I did the socket bit (apparently must be non switched?). Wouldn't work with either. I had assumed it was because of 'purity-of-sine-wave' issues rather than earthing. Worcester Bosch gas combi.I'm a bit surpised nobody has popped up yet who has actually tried it.
Bit more description for the dimmies pleaseMarty.My combi works just fine on my little 1000w genny and has done with both an earth rod banged in and using a genny switch to wire the house TNS earth to the genny.
