How to connect TV to the internet?
15 Nov 2017
Hi all,
I have a Logik L39FE12 and wondering how I connect it to for instance watch shows on YouTube and other online things via my phone/laptop/desk top etc?
Here's a pic of the back of it.
I do also have a sky q box.
Thanks all
I'm afraid your TV is not a "Smart" TV.
It will not connect to the internet by itself.
Either use the apps on the SkyQ box, or get a FireTV stick, or Roku box for the full "Smart" TV experience! :)
Thanks, so if I buy a firestick, plug it into the spare HDMI port on my TV it will wirelessley connect to my phone or laptop? And then I just play what I want on my phonr/laptop and it will pay on my TV? Is this right?
You could also use a Chromecast which allows apps on your phone to stream to tv, all require hdmi connection (does your tv have?).
About £20 used, lots around.
To some extent, it will.
You can 'cast' content from your phone and laptop, but a lot depends on the compatibility of the apps and devices you are using.
Using the inbuilt apps on the firestick is a far slicker experience.
Not come across any app I use that’s incompatible with my Chromecast .
You can buy a basic Firestick, then if you have wifi available for the Firstick to access - then it can access lots of sources on the Internet such as Youtube, all the catchup services, browsing and lots more. If you don't have broadband and a router with wifi, you can usually set up a wifi hotpot on a phone, for a Firestick to connect to.
The Sky Q box has "Apps" on the main menu. Prime, YouTube, Disney, Netflix etc.
It must be connected to the internet already, just go through the menu to open them and sign up
If you want to play things that are actually stored on a laptop or similar, get a Chromecast, plug it into an HDMI, and cast to it
