Ukraine counter offensive
I dare say atrocities ?? Have been. Committed by the Ukranians
( certain)
There is also the issue of retribution on those areas which are liberated from Russian control
Those deemed to be collaberaters ? ?
A complete mess
Israel are somewhat concerned about the mad mullahs involvement in the ukraine
They have the mad mullah militia on there borders
The head of broadcasting from state funded RT news has called for Ukrainian children to be drowned, and that Ukrainian grannies paid to be raped by russian soldiers, RT news is a favourite of certain posters on here, just shows what a vile person they are.
Some of those atrocities are proposed and supported by some on here..............
Shooting asylum seekers, indiscriminate bombing of civilians........
Mind you although the mad mullahs
Are well up on atrocities / torture ect I doubt they need to advise the russians
On the subject
A spate of speed camera thefts in Sweden may be supplying Russian drones used in the Ukraine
Over a 100 such cameras have been pinched from the road side
Over half of em were pinched in one day
Just the camera part of the equipment has it is being pinched
The cameras are the exact same model as used in Russian drones
The Belarusian armed forces are staffed via conscription and are likely to have the views of the civilian population ??
Making Belarus a combatant could cause masse protests
Even the possibility that they would surrender en masse ? Or even switch sides ???
The cameras are fixed focus cameras. They're useless for anything other than 50 feet away.
Apparently the mad mullahs drones don’t have cameras ( some) so they fly blind
Putin has struggled to import electronic equipment / components due to sanctions
The swedes are aware of the potential theft to supply the Russian s and the mad mullahs
Swedish plod are reporting over 160 thefts
Russian drones taken from the battlefield use exactly the same cameras
And are attached to the drones in exactly the same way
Russians and the mad mullahs ?? ;) ???
For a drone camera to be of any use one needs to specify the purpose of the drone:
1. Surveillance - as the speed cameras are fixed focus cameras. they'd need to be a set 50 feet away from that being surveyed. That would make them very susceptible to being shot down, and render most of the footage unusable.
2. Attack Drones - If the objective is to capture the immediate view prior to the drone's impact, the footage would give only one usable frame. So as good as useless.
3. Blind attack drones - don't need cameras.
4. Target Practice drones - don't need cameras.
Ah, if only there was some way a lens could be changed.
According to Nikon, it's a highly skilled job, even if they knew how to do it, and had the supplies.
The customized Nikon cameras that Sweden uses
The lens will be out of focus at any other distance, Ms. Lundberg said: “It’s not possible to adjust this, according to our supplier. Not easily, at least.”
The Canon EOS 800D DSLR (similar to the Nikon) and found on the drones (not a Nikon) is available on the open market. Second hand for about £500.
There appears to be some discrepancy over the make of the caneras:
In it sits a Canon camera attached with velcro to a small steel plate, the same model of the missing Swedish speed cameras, Swedish newspaper Aftonbladet reports.
Dunno
Only reporting what has been reported
Swedes stated that they are the exact same camera as used on some drones ?
Only the camera part from the speed cameras have been taken ??
160 they reported pinched over a short time period ??
Russians are short of certain / all equipment ???
Plod are investigating the thefts
Russian defence minister is accusing or suggesting that the Ukranians are planning to use a
Dirty bomb ?
Russians and Ukranians have been in sort of talks US UK France and the Turks were also at the same meeting ?
