Hi all. any help is gratefully received!
I installed a Nest (DIY) back in October but I have since realised that it was not working as expected.
It does not seem to be using the tank stat and hence I suspect that I am using a lot of gas. Not good at the moment.
It was also not firing the boiler for calls for heat, instead just pumping any hot water that was present due to a previous call for hot water.
I believe that I have a 1990's style S-Plan with no zone valves. Instead I have seperate pumps for H and HW. I also have a non-powered valve that diverts water to H or HW. Not quite sure how that works.
The tank is (I believe) a thermal store.
Pictures attached are all before I made any changes. I will then post pics of where I am at.
Don't reply yet - part 2 to follow.....
