Hi all.
A customer has Lutron Rania light switches. She wants to dump the halogen/incandescent bulbs (E14 ses) that she has on her chandeliers.
She purchased 4W Sylvania candle LED filament bulbs. I suspected that the switch would not function properly if I swapped out all of the 10 times 40w bulbs for 10 times 4W bulbs. I got to the point where it only one incandescent bulb needed to be kept in place.
I have since checked the specifications for the dimmer
It looks like the minimal load is 50W and that it auto switches from leading to trailing edge.
Would having a single incandescent with LEDs cause any problems with the Lutron? At £100 to £150 for each switch, I don't think she wants to replace them.
I am currently trying to find E14 bulbs that have sufficient wattages to work once I swap out some of the 4W bulbs.
She also has GU10 bulbs that work off the other side of the switch, again, I guess that I need to ensure that the total wattage exceeds 50W.
And finally she has some regular dimmers. the push/on off rotary types. Recommendations to replace the modules to work as low as 12W would be greatly appreciated.
Many thanks
Many thanks
