Pumping station advice
7 Apr 2005
Hi i am looking at a pump station for our extension to pump up to our sewage pipe about 3metres away(very slight incline).
The extension has a guest toilet, washing machine and sink (utility)
I was looking at this :
There is a 290 litre model almost same price compared to above as it includes high level alarm. Do i need the larger as i guess it needs a bigger hole, if it's going to be pumped anyway im not sure how larger tank helps? TIA
The one in your link seems to be cheap, maybe too cheap at first glance. The size of the tank that you buy depends on what appliances are connected so best to talk to the seller but yes to the high water level warning alarm.
Ask if the cheap one has a sealed lid to stop bad odours leaking out.
These work in our rental chalets. Pumps 2m up and 7m along to sewer - used for shower, sink, toilet.
Dont think that you meant to connect the washing m/c to an Access 2..
Why a washing machine has less flow than a sink or a shower or a toilet...they don't seem to care about the source of the water.
Go ask Saniflo but I suspect pressure and tempreture of discharge water might be in the answer.
This is what you call a pumping station.
