So if you were me you would just charge them somewhere else?All our shavers and toothbrushes I cut 2 pin toothbrush plug off the cable and put 3 pin plug on vs adapters. They are 240v so fine.
You can buy adapters cheap from many places if you don't want to do that
www.plumbworld.co.uk
You can’t charge them from mirror or wall sockets. The 2 pin charging lead on my cordless shaver is not the same as the 2 pin socket in my mirror.Shavers are cordless so charge somewhere safer away from water imo
The 2 pin sockets on wall mirrors and shaver sockets are universal and take UK, European, and US 2 pin plugs. Some even take Australian plugs.You can’t charge them from mirror or wall sockets. The 2 pin charging lead on my cordless shaver is not the same as the 2 pin socket in my mirror.
Anyone installed/have a croydex mirror, are they any good,thanks.Cheers, seen this.
Anything I should be mindful/wary of?
Any one is installed one of these or any other croydex mirrors?
Croydex Hang 'N' Lock Chilcombe LED Bathroom Mirror & Demister
Croydex Hang 'N' Lock Chilcombe LED Bathroom Mirror & Demister Pad 500x700mm Mains Power -. Lowest price guaranteed. In stock: Delivery Next Day.www.plumbworld.co.uk
Thanks again.
Weird. When I first got the mirror cabinet about 15 years ago, I thought I’d be able to charge my shaver up. It absolutely definitely wouldn't accept my shaver lead - the pins were either just a little too far apart or too close together, i can’t remember which. Three shavers on and I actually tried the current lead in it last night and it fitted! I doubt if it would work for me though because the plug is quite chunky, as if it’s a transformer or something and my socket is fitted inside a mirrored cabinet at the top, facing downward and the weight of the 'transformer' would pull it out.The 2 pin sockets on wall mirrors and shaver sockets are universal and take UK, European, and US 2 pin plugs. Some even take Australian plugs.
What 2 pin plug has your shaver got on it? Photo if you don't know.
Well, I actually just tried it. It will charge but only if I get it in the correct position and I have to hold it there so not quite useable.Weird. When I first got the mirror cabinet about 15 years ago, I thought I’d be able to charge my shaver up. It absolutely definitely wouldn't accept my shaver lead - the pins were either just a little too far apart or too close together, i can’t remember which. Three shavers on and I actually tried the current lead in it last night and it fitted! I doubt if it would work for me though because the plug is quite chunky, as if it’s a transformer or something and my socket is fitted inside a mirrored cabinet at the top, facing downward and the weight of the 'transformer' would pull it out.
