substitute for long euroscrews
15 Nov 2005
South
Cook Islands
i got hold of some used Kesseboehmer iMove pull down shelves. The fitting templates say they need 6.3mm x 48mm
Euroscrews. It is because they pass through the thick plastic pivoting sides. I can't find longer than 25mm
what can I use instead?
I have not yet drilled the cabinets, which are laminated chipboard.
A random search of those dimensions name up with this link and dimensions
Blup
Furniture screws, eh. Thanks. That seems to be it
(Though the one illustrated in the instructions is a Euroscrew)
Might also be called Confirmat screws.
For the benefit of non-Europeans, the Euroscrew for kitchen cabinets has a thick, unpointed shaft, with a coarse, biting, untapered thread, I suppose to take a lot of weight in quite a shallow hole, in weak material, and a relatively small countersunk head. They are usually much shorter.
These are the things. Mine are the doubles. Because I have 900mm height wall cabs.
Turn off the annoying sound.
Confirmat screws is what i know them as.
Blup
