2 different exterior paints?
11 Jun 2016
Afternoon guy's, got two different makes of paint. I want to paint 2 exterior walls this year & would like to know what difference is between these two tins/tubs.
I bought them off the previous owner, without actually knowing much about them. There both brilliant white, so could i use them individually or would it be best to mix together or not at all? Cheers for any replies
The sandtex paints are the same, water based.
Powerkote I think is solvent based, so you can't mix it with the sandtex.
Do you know which one is the better of the two? The walls are rendered, if it helps.
