Hello,
Firstly please excuse my lack of knowledge with heating systems, ill Try and explain what I’m Trying to achieve the best I can.
As per the description I have a 428 heat only boiler recently converted from open vent to a sealed system. This is operated by a Yplan and Hive controls.
The boiler has 2 dials on the front with the option to control both the radiator and water temperatures separately.
When I try and heat either the radiators or the water cylinder the boiler only achieves the temp that the radiator dial is set at.
Unfortunately the water dial d temperature does is never achieved and I’ve been made aware it won’t while I try and control it with Hive.
My question is would utilising the the eBUS Connection by replacing Hive with the latest Vaillant controls give me better control of the boiler? VR66 and Sensohome?
Ideally I’d like the flow temp from
The boiler to be around 40-45 degrees when heating radiators is requested which would increase to 65 when hot water is called for.
Basically want the heating ticking over but the cylinder heated up much quicker when it’s requested. I understand this would increase the temp of the flow to both the rads and the cylinder but would only be for an hour or so in the morning.
Hopefully I’ve made some sense, and someone with knowledge could tell
Me if this old boiler can be controlled the way I want.
Thanks in advance
Craig
Thanks in advance
Craig
