- Joined
- 17 Feb 2019
- Messages
- 280
- Reaction score
- 19
- Country
Hi all,
I'm trying to track down and fix a problem we've noticed this Winter where we're waking up to a really cold property, some mornings it's been as low as 7.5 degrees inside and we believe there's likely a bunch of issues contributing to it. We're dealing with fixing the loft insulation on a separate post(which has become quite a long thread)
Last night for example, we had the heating on for a couple hrs, went up from 12degrees or so, upto 17space, which is fine, but woke up again this morning to about 11ish, over the space of only 8hrs or so. I've atached the hive logs so you can see how quickly it's dropping too, this is not normal right? It was about -2 overnight outside but even still it seems like it's dropping super quick.
I've noticed the landing floor is always cold, so I lay down on it earlier today and I can feel a slight cold woft of air and have noticed some fabrics on the stairs moving round a bit as if being gently blown by wind, the wife think's its just convection of air but im wondering if its a draft on the landing somewhere. Pic below (thermostat in purple)
I guess a couple questions based on the above,
:- What's the best way of tracking down the source of drafts? I tried for 30mins this morning holding my hands to surfaces and slightly gaps in the landing skirting boards etc, but no joy.
:- where the ground floor vertical windows are on that photo is a recent small front extension, If any of that was letting air in, would I be feeling that on the landing floor higher up than it? or is it likely coming from a different source, such as the big landing window? or somewhere higher up?
:- fixing Poor insulation in the loft isn't going to fix the symptoms i've explained here right? im correct to assume this sounds like two seperate issues that both need addressing?
thanks so much,.
Ged
thanks so much,.
Ged
