Thanks, that was a quick reply.3 Amp
It was a simple question!Thanks, that was a quick reply.
When you know the answer everything simpleIt was a simple question!
Dunno where you get that idea fromWith tungsten the limit for a flood light was 150 watt without planning permission, I don't know if the law has been rewritten using lumen instead of watts? But with LED one would normally consider 30 watt maximum to comply with the sprite of the law.
Indeed. I must be one of the few people around who uses a lot of 1A fuses - not really necessary, but 'why not?' if they are adequate?1 Amp will do, too.
Quite so, but eric is always making that assertion.Dunno where you get that idea from
https://www.planningportal.co.uk/permission/common-projects/lighting/lighting-planning-permission clearly states otherwise for domestic at least.
Agreed.50 Watt LED is imho going to be far too bright as a replacement for the OP's 300 Watt halogen floodlight (which would likely have had a 3 Amp fuse in the supply).
Approved Document L (which, unlike the Building Regs themselves, is not 'law') contains only guidance/recommendations, not any 'requirements'.Building Regulations do apply though .... and have that 150 Watt number mentioned (with no differentiation between LED or tungsten halogen on that page - the regs may be more specific, or not?).
True, but you are again talking about recommendations, not 'requirements'.A >40 lumen per watt efficacy is required (50 Watt x 40 = 2000 lumens) so the 50W led floodlight will easily surpass that requirement.
