Further to Dazlights advice, i have a P5 chipboard floor that i am going to overboard with 5.5mm ply prior to fitting Camaro LVT.
There are a few dips in the existing chipboard that i want to level out. Would it be best to use a suitable SLC over the chipboard first, then overboard with ply and then use feather finish over the ply joints and fixings..... or is it better to lay the ply down first, before slc, and allow the dips to transfer through to this and then use slc over the ply.... just wondering which way round.
Previously ive used ring shank nails to overboard.... is this the best fixing? Bear in mind its 50 sqm.
Also - when laying herringbone - i have a T shaped space to fill. Does it look ok to have the floor direction running up the spine of the 'T' and then turning 90 degrees to the left into the left room, and 90 degrees to the right into the right room..... or is it more asthetic to keep the direction constant. There is no divide between the rooms. Basically, imagine the spine of the 'T' is the hallway, the left bit of the 'T' is dining room, and the right bit of the 'T' is the kitchen.
