Wall hung toilet pan, how secure and safe are they?
2 Feb 2016
I’m looking to install a wall hung toilet system that comes with the metal frame. Looking at all these systems they all have similar installation method where there is essentially two bolts coming out of the metal frame. The toilet pan the. Hangs on these two bolts flush against the wall and frame.
My main concern is how secure are these? Like I know ceramic is quite fragile too. Like if two bolts are come out and attaching the the pan, surely there must be some sort of plastic sleeve so that the metal bolt isn’t directly on the ceramic and how do you know how much to tighten the nut? Because I’ve heard people overtighten nuts on ceramic causing the ceramic to crack. So essentially that entire toilet pan weight plus the person sitting on it is being held by the two bolts ?
They have been stress tested to take heavy loads, details of which can be be found in the specs sheet.
They're used all over the world including in many hotels. They're perfectly strong enough
My main concern would be having something substantial enough to fix the frame to.
Of course, the metal frame is only as strong as what it's fitted to. Needs to be suitably anchored into the floor and brick wall or well secured wooden framing.
Thank you all for your replies. It’s reassuring :)
I’m looking to get the Gerberit UP320 frame with the Sigma cistern. How do I know which toilet pans are compatible with this frame?
Pretty sure they're standardised - the position of the flush pipe, soil pipe and mounting studs in relation to each other and the ground are universal.
