Hi All
Do most zone valves use compatible nuts & spacing for a swap?
I have a failed Honeywell 2 port. The other zone uses a Drayton which has been very reliable.
Can I try and do a quick swap to a Drayton (towels in place)? If I need to cut olives / pipe then it'll be a drain down job which is a pig since it's a one story flat and the zone valves are at near floor level with no easy way to drain the system.
In that case the local Toolstation has a "Corgi" branded Honeywell copy so I'll get one of those.
