That's how it's done in new builds but the pipe is only 10mm I think. Personally think the way the pipe enters the valves looks a dogs dinner but it's your choice.I've seen this product, do you think this would work. Could the pipes come up from the bottom and into cavity then out of this connector? View attachment 296475
Yes you can do it that way but as @ktuludays says, it looks rather pony. Plus (in your case) you'll have a couple of pushfit converters hidden under the floor or in the wall which is not ideal.I've seen this product, do you think this would work. Could the pipes come up from the bottom and into cavity then out of this connector? View attachment 296475
Yup, that's the neatest way to do it.Yeah, I think the less connection in the cavity the better.
Going to go with copper pipes coming out the wall, something like this.View attachment 296794
Unless you specified you wanted it all as soldered copper then it's ok.So we got someone out to fit the new pipes for radiator, pipes coming out from cavity.
What do you think of job?
Is this the best way to do it?
Cost was £90 for parts and I think it was about 2 hours.
I didn't specify what I wanted. I assumed it would all be soldered copper.Unless you specified you wanted it all as soldered copper then it's ok.
Personally as it's gonna be hidden and under a floor I'd have used full soldered copper and had a bend rather than joint in the wall.
Is it pressurised currently? Before you cover it I'd make sure it has water in it and is leak free
He fitted the studs and has marked the floor so I assume he's measured it for the radiator bracket. He says to contact him once finished to fit rad.As above- burying compression fittings in the wall and pushfits under the floor wouldn't be my first plan. Those notches in the joists are a bit big (but they look quite old so maybe not your handypersons fault).
Have you checked your radiator to see where the brackets go- those studs may or may not be in the right place, consider noggins between them rather than fixing to plasterboard.
