Replaced an upstairs radiator yesterday.
Partially drained the system, modified the pipework, refilled and check for leaks. All good.
Run the HW 30 mins in the morning and again in evening.
Noticed not much HW yesterday evening and none this morning.
Conventional boiler (old Ideal Elan) with HW Tank in the loft
ST699 timer. Boiler springs to life if I override HW
Wiser controlling CH only. All working.
V4073A 3 port - changed the motor in 2007 due to no CH (My first post on here!)
There is very little resistance on the lever. Should there be?
I can't think how changing a radiator would have caused this. Maybe just coincidence?
Quite a lot of gunge in the F&E tank. I did clean out before refilling.
Pump a bit noisy after refill but has settled down again.
