How to install a shower screen with a notched tile?
26 Jan 2023
Dremel, multitool, and angle grinder all have diamond attachments you can use for cutting and grinding tiles. You can use them to make a channel in the raised tiles. Tiles are brittle and there are risks of unintended damage. If you are extremely careful, you might succeed.
Cant see how deep notches are ,cant you put a bead of silicone on the frame work to fill the gaps and silicone up down frame afterwards
Or if there is no close wickes, can be had on eBay for around the same price. I rate it
Also rate their limescale remover for cleaning lead stains off glass
What is the best way to overcome the notch
Best? Notch the screen holder or flatten the tile
Don't worry all. I am resealing and re-grouting the mouldy parts. (Dirty tenants)
