Hi, if I twist off the tap and hold the nut at the bottom to loosen the tap from the sinkp,
then use a couple of spanners or wrenches to remove the other compression fitting end of the tails,
then just pull the tails through the hole in the sink will that work?
Then do the opposite to fit the new tap.
