Painting over Shiny wall paint
  • Thread starter Thread starter Deleted member 282503
  • Start date Start date
D
Hi
Have some purple walls in the new house. The paint is very shiny. I was wondering if it could be gloss but it doesn't come off in the same way the door frames strip.
Would I have to sand the shine away before a fresh coat?
it is most likely ‘silk’ emulsion- horrible stuff. I have no idea why people use it.
No need to sand - but the new emulsion may sort of slide around on it a little so two coats will likely be required.
Use Matt finish emulsion on walls - much more forgiving and softer on the eye.
Personally, I WOULD sand all over - that will ensure a good key for the new paint.
Why take the chance?
You don't want the new stuff to peel off easily.
I'm not sure I would describe silk emulsion as "shiny."
It might be some kind of gloss.
Matt holds dirt and is harder to clean.
+1
Sand it down either with a sander, a pole and sanding plate or by hand.
Then dust it all off, wipe all with a slightly damp cloth and then paint.
