pyronix manual and Qs
17 Sep 2004
Just moved in and there's a existing alarm - I think Pyronix though no manufacturer name on the unit. Seller left me some tags, which work to turn it on/off, together with a note of the code and installer code.
I have no wifi yet, so should it still set off the external alarm?
If I want to change the code, is it possible and where do I find instructions?
You will need to ascertain the model so that you can find a user guide
Control panel could be pyronix 46s or Enforcer with remote keypad.
Changing code is same function for both models
You need to confirm if system has wifi connection as both panels can work without.
Have you a app system I'd?
Thanks. No app and no wifi in the house. Will PIRs work without wifi?
Change master code - press D , enter your master code press no until it asks to change codes or edit users.
Press yes on that then no until it says change master code.
Press the C button to clear existing and then type New code followed by the yes button.
Press no until it says change codes/edit users again.
Press A to save and leave menu
Change engineer code-
Enter engineer code, press no until it says change codes press yes on that
Then yes again
Followed by no until it says change engineer code press yes
Press C to clear existing
Enter new code followed by yes
Press no until it shows CHANGE CODES again.
press A to save and exit
It looks like the 46s so thanks for IDing that.
I've searched for user manual online, both the Pyronix website and 3rd party manual sites. Can find the 'installation manual' but not the user manual.
Anyone have it or know where to find?
User manual on Pyronix website.
Just Google Pyronix euro 46 v10 user manual .It's there 100%.
46v10 is the correct user manual.
46s = 46 control panel in small control panel housing
46 L = 46 control panel in large control panel housing.
What are you wanting to find out what to do ?
Thanks. Well as wellas changing the code I'd like to know what that does to the tags (if anything). Do they still work or do they need programmeimg in some way with the new code?
Limited use changing the code if someone already has a working tag that continues to work....
A tag is assigned to a user.
When programming a code instead of inputting new code number you present the tag to the keypad.
The level of authority depends on how user can use code/tag.
Master can control whole system
User depends on what level that is set to.
