Powerflush, yes or no?
11 Feb 2008
I've been getting quotes for a new boiler. The house is 17 years old and it's the original boiler. When fitted the system had sentinel X100 added.
So far I've had 4 quotes. Two of them said you'll need a power flush as it'll invalidate the boiler warranty. One never mentioned it. And the last guy made a point of saying you don't need a powerflush as long as the system is fully drained and a Sentinel type chemical is added with the new install it'll be fine as modern boilers have a fliter.
So who is correct?
Doubt it will need a powerflush get some Sentinell x400 and stick it in the system for a week before they come to fit the new boiler, open all radiators and run the heating a few times per day then get them to add x100 once they fill the system back up after fitting the new boiler
Not true, the warranty is only invalidated, if the boiler is damaged by your system being choked up with debris. If your system has been properly mainted since install, there should be no debris needing to be cleaned by a power flush.
First two have lied to you .
what type of system do you have at present are you changing the type . do you have any rads with cold spots /patches on them .Has the system been drained over the past 17 years for fitting of parts /rads
We've lived there for 4 years so I've no idea about the system being drained. We've never had any parts replaced that required a draining. Rads seem fine, although I've not checked them recently. It's a heat only boiler with a pressurised hot water system.
How do i "stick it in the system"? Is this fairly easy? I'm no plumber.
Is this your 'stay-in' house for say 20 years or a stepping stone? If the former, when you choose an installer whose judgement you trust ask how much. He's there on the job, say it adds £350, over 20 years you've lost nothing and have started from a known good position rather than a maybe.
Of the latter and you'll be gone in 5 years, take a chance.
