Ceramic V Oil Electric radiators
28 Jun 2021
Hi
Re: ELectric Wall Heaters
I came across Ceramic Electric Radiators. What are they like cost running wise compared to electric oil filled (fluid filled) rads? Buying prices are fairly similar.
There is also panel heaters and convection fan heaters which are cheap to buy but expensive to run, correct me if wrong.
If they are the same power input, the operating costs will be exactly the same.
That applies to all resistive electric heating.
The only difference is some types (convectors, fan heaters, radiant) provide heat instantly and stop providing that heat when off.
Others heat up various materials (oil, ceramic plates, bricks) and take longer for heat to be provided, but stay hot for a while after switching off.
In every case, the heat provided and the electricity used is identical.
There are plenty of vendors claiming their heaters have magical properties and cost much less to operate and provide more heat than anything else.
They are all 100% lies.
What do you read into this:
Do panel heaters use a lot of electricity?
Panel heaters are less efficient than electric radiators because convected heat is inherently less efficient than radiated heat. This means that you'll need to use more power to heat your room with panel heaters than you would with energy efficient electric radiators.
There are three types of electric heater, inferred, resistive, and heatpump. After that one looks at control and distribution, so if we look at resistive to compare the different heaters we are looking at speed to heat the room, and speed to start and stop heating, and the major word is hysteresis, this is how unstable the temperature is, we aim for no hysteresis but this is near impossible.
1000 watt is a 1000 watt be it a fan heater or an oil filled radiator, or even a storage heater, the difference is how the heat is stored within the unit, so we look to the maths to start with.
So a oil filled radiator needs to be switched on say ½ hour before you use room and the fan heater ¼ hour before you use room, so if you use the room for 1 hour then the oil filled radiator is 66% efficient, but fan heater 75% efficient. However the fan heater is moving the air, so whole room is at the same temperature, but the oil filled radiator uses convection currents only, so next to window will be cooler, and next to radiator warmer, so the losses through the window are less.
A on/off thermostat will have a slewing range, the temperature it turns on at and the temperature it turns off at, the small the range the lower the hysteresis, but also it will wear out the contacts of the switching device, so storing some energy helps with on/off control, also there is the human factor, if we hear the fan stop we feel cold.
So although first glance the fan heater seems best, in real life the oil filled radiator can do better. But the time we heat the room for will change which form of heating works best.
The ideal would be to have solid state control, so it can turn heater on/off many times an hour without the contacts wearing out, or some other electronic method to vary the heaters output, if we look at a standard central heating radiator the TRV (thermostatic radiator valve) does not turn on/off but slowly opens and closes giving an analogue temperature control, far better than digital (on/off) and even with digital control better thermostats use a mark/space ratio so start switching on/off before the set temperature to stop it over shooting so reducing that hysteresis.
With electric resistive heaters it does depend where the temperature sensor is, if we establish a thermal air flow then under the heater or maybe slightly to one side a sensor should be measuring temperature of the return air, like the TRV does with a central heating radiator, so is measuring the whole room, however when the heater turns off, the air flow reduces, and we get some radiant heat going down, cleaver electronic thermostat can use algorithms to counter this, but often we use wall mounted thermostats, these have a number of problems, one is mounted on a cold wall, but also needs to be were we can reach to adjust, and where we can see to adjust, so the government has given us a very small option from memory 1200 - 1400 mm above the floor, but we want most of the heat when not expending energy, so when sitting down, so having the sensor on a table in middle of the room is likely far better.
I honestly can't work out why some heating systems are used, if we take an example of say the kitchen, likely a easy clean floor which tends to be cold, and a lack of room to fit heaters, so two options, kick space fan heaters which are going to blow across service of floor so will warm the floor a little, and also heat the room fast, or under floor heating, again will warm the floor but take an age to heat the room, which is likely only used a few hours a day, so kick space heating is clearly way to go.
So what have I missed, why would anyone fit UFH? I can see point in old peoples home where rooms heated 24/7 and health and safety means we don't want hot radiators, but in the main UFH is non starter, but people fit it, why?
So we look at the room, and the home, a two up two down town house with no back yard and no street gas, so no room for oil tank or LPG tank within the safety limits required, no option but electric, the AC we used in warmer countries mounted in a box in the wall can clearly heat and cool the home with a lower running cost to a resistive heater, but is expensive and requires maintenance, but at least a standard size so easy enough to slide one out and side another in. The air source heat pump would be likely best option.
Inferred is hard to control, standard wall thermostats don't work very well, but a mixture of inferred and resistive heating can and did work very well until the government stepped in, heat the room to 18ºC then in the evening when you want it a little warmer use tungsten lights which give off inferred heat so make room feel like 20ºC when I removed tungsten bulbs I needed a programmable thermostat so room warmer in the evening. However changing a bulb some where in the house every two weeks was not good, so glad gone to LED.
But a resistive heater is a resistive heater, only way one is better than another is how it is controlled.
Are you on another planet? Most homes during the day have windows to allow light in, radiated heat can pass thought most glass, so much of the heat is wasted, only at night is your statement getting anywhere near when curtains are shut. But the biggest problem with radiant heat, is control.
Typical radiant heater
first thing you notice, is split into 4 sections, so you can select 4 levels of heat, be it electric or gas does not matter, you can't use standard thermostatic control, when you turn it on you feel immediately warm and when off immediately cold, as a supplement to convection heat to boost a room when in use yes, or as short term heating in a church hall yes, but in the home no, at least not as the only heating, in the main efficient electric heating means well controlled, and controlling radiant heaters is a nightmare.
A fundamental deficit of understanding, based on a mostly unrelated fact.
In some situations, radiant heat is more useful as it heats objects rather than the air. Those dreadful patio heaters being one example - they can heat people and objects in front of them. Outdoors a convector heater which heats the air would be useless, as all of the heat would be carried away by the air.
Indoors it's irrelevant, as generally people want the air heated, and it won't be lost as it's usual for people to have doors and windows closed when the heating is on.
Radiant / IR heaters exist for indoor use, ideal for people who want to be roasted by radiant heat while sitting in an icebox.
There is still no efficiency difference, it's just how the heat is provided.
Oh dear what a load of rubbish, it is nearly as bad as the government advert for Smart Meters. But if the government can get away with showing a guy clapping hands to turn lights on/off after fitting a smart meter, then I suppose they can now get away with anything?
My old house did have a ceramic gas heater, and it was a pain, as no thermostatic control, so room would get slowly warmer and warmer, not until one walked out of the room and back in did you realise how hot.
Maybe a report should go to these people https://www.asa.org.uk/ but if they can't stop the smart meter add I don't hold much hope.
Q. Occasionally, I need to heat one bedroom in my house before sleep when alone. I have 16 rads, gas boiler 25KW boiler, surely 1KW (or less) electric heater is more economical than CH. Which type of electric heater shall I buy?
If you heat one room, it will require less energy than heating an entire house, and therefore cost less than heating an entire house.
Gas is cheaper than electricity, so the same energy from gas will be cheaper than the same energy from electricity.
Using less of any fuel will cost less.
Personal preference. It makes no difference to the cost of operation.
I know gas is cheaper but am not going to turn off 15 rads at night and 15 rads on next day every time. They are balanced rads so hassle and possible mistakes.
I am comparing 22KW boiler to heat 16 rads when one room is used against a 1KW electric heater. 1KW electric heater will cost max 34p/hr and boiler will cost over £1/hr, with today capped prices.
Anyways, after further consideration, my choice is wall mounted oil rad.
