Hi there, wondering if anyone can give me some advice please.
In my kitchen I have a cooker switch with a plug socket which I believe is on a dedicated circuit. If I test it with a Voltage Tester it read all correct as it should. Now if I turn off the Mcb on the CU which is labeled "Cooker" it still shows a Voltage of 3.
On the CU there is another mcb which is labeled "Sockets" which is powering the washing, dishwasher, hob, and hood on a plate with 4 switches and 4 fuses altogether and also a separate switch with a fuse powering the fridge.
If I turn this off there is no Voltage to the Cooker Switch/Socket.
I want to know if this is normal or not please?
I have attached some photos if that helps at all.
Thank you in advance
