On a Linea Max ? really ? mate if you have problems removing that cover you should not be allowed near sharp thingsHardest part of the vokera, is getting the cover on and off.
What I wrote was attention to other components on that model like expansion vessel ( almost always- ones I looked at- has water air side), auto air vent, main heat exchanger scaling up where primary flow enters the HEX, pinhole on the main HEX, flow isolator blockage on filling loopI am intreagued Dan , so what else could cause heat bleed to rads when HW only running on a Linea Max ? always happy to learn mate
Sounds like some of our boiler setups, not been installed to industry standards, mi’s et al, and no fault of the boiler.What I wrote was attention to other components on that model like expansion vessel ( almost always- ones I looked at- has water air side), auto air vent, main heat exchanger scaling up where primary flow enters the HEX, pinhole on the main HEX, flow isolator blockage on filling loop
Yes Dan some valid points there but none would cause heat leakage to Rads when HW only is on , which the post is about, have you ever seen a Primary heat exchanger scaling in Scotland ? we dont have any hard water areas, never seen any scaling, the heat exchangers do leak at the rear left hand side, the weld pinholes, this is because Vokera changed the manufacturers of the primary heat exchanger many years ago, and the wire used for the weld failed after a few years, sometimes it might be more expensive , but stick with what worksWhat I wrote was attention to other components on that model like expansion vessel ( almost always- ones I looked at- has water air side), auto air vent, main heat exchanger scaling up where primary flow enters the HEX, pinhole on the main HEX, flow isolator blockage on filling loop
Yes. Plenty of times. Where the primary focus water enters the HE, the POC passing through the matrix will deposit green crystals and then black, resulting in total blockage to POC where the blockage occurs. Not the first time I have removed the heat exchanger from the boiler to dislodge the hard scale with a screwdriver to then wash the HE under fast running tap. This is on the air side not the water side as you suspect I intimated.have you ever seen a Primary heat exchanger scaling in Scotland
That is not scaling mate scaling is a build up of calcium within the waterwayIan what I posted was in addition to what you posted ie to keep the boiler operational.
It is a product of combustion when the hot gasses react with aluminium fins on copper heat exchangers, it is called vivianite, when it blocks the narrow fins then carbon forms as part of the incomplete combustion , hence why part of the heat exchanger will "soot" up, and you get black powder on the heat exchanger, never clean the heat exchanger without safety glasses on, one tiny speck of that in your eye and it is hospital time extremely aggressive, horrible stuffOk. What is it then?
I think what Ian said is what you call scale is actually vivianite and scaling, again what Ian said is calcium buildup in the waterways, correct me if I’m wrong @ianmcd.Ian I said that already.
Thanks for identifying the scaling
you are correct @CBW , many older boilers used similar heat exchangers and if not serviced properly then this build up became like a cycle the more blocked they became the more carbon it produced, , same with BBUs, these days companies call a service a poke and go, modern boilers dont suffer the same as the older ones did, but even then you still got lazy feckers who never serviced anything properlyI think what Ian said is what you call scale is actually vivianite and scaling, again what Ian said is calcium buildup in the waterways, correct me if I’m wrong @ianmcd.
No Dan scaling is a completely different thing, Scaling is caused by calcium build up in waterways,Ian I said that already.
Ok. I accept scale is only from hard waterI am intreagued Dan , so what else could cause heat bleed to rads when HW only running on a Linea Max ? always happy to learn mate
