Weed or plant.
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
I get this plant growing in my garden which I am always digging out complete with the bulb where possible ( bulb some times does not come out as the plant separates from it).
The leaf or foliage is green with off white trace along the edge. Looks like a grass leaf
The neighbours garden is over run with these.
Can I put some sort of edging to keep this pest at bay?
Thanks for reading.
These type of plants have tubers(?), at the base, (bulb as you call it. Each year they divide so there are more of them in the ground. You need to remove every single 'bulb', which is more difficult than it sounds, as any single one, be it ever so small, will simply re-grow.
I would advise using a contact weed killer, the type you brush onto the leaf stems, for it to penetrate to the roots of it and eventually kill it.
Putting any kind of physical barrier, such as edging, will not help as it needs to be killed at the roots.
  • Thanks
Reactions: DP
Could this be an ALLIUM one of the Onion family
If this is the only one in your garden I would put it in a pot and see what grows.P6100099.JPG
  • Thanks
Reactions: DP
