Good Morning. The boss insert to the strap on the soil pipe has come out as it looks as though the weld has failed and the sink waste is leaking onto the patio below. The pipe is welded at both ends so I can't remove it to replace weld in a new boss. It appears as though the only solution might be to cut the pipe in the middle, pull the pipe and boss end out of the soil pipe and join a new piece of pipe where the cut is made. I hope this makes sense and if anybody has a better (easier!) solution, then I'd be grateful.
Thanks in advance.
Thanks in advance.
