Anyone with a ladder will be able to look and take a photo.
If roof tile is broken, then an easy swap for a new one.
Yes the water will run down felt into the gutter. I've known houses where that's happened for years unnoticed. Not a problem If fixed
Window cleaner was over and had him take a peek.
No obvious missing tile(s) but he did notice the following - roof tile
Zooming in it does look like some damage with hole? No idea how this could have happened.
But does seem to correspond to what I'm seeing inside the loft area huh? - loft daylight area
Hopefully this means its an easy tile swap...
Also, assume these are a common type/style of tiles that are readily available?
