- Joined
- 8 Mar 2010
- Messages
- 315
- Reaction score
- 7
- Country
What ho one and all,
I have a MVHR unit in the loft and recently, when it starts, the Alarm light is illuminated. The manual says that the incoming thermostat needs manually resetting but this involves clambering into the loft every time. I want to replace the stat but as it is a Swedish unit, they will not ship the part to the UK.
I is a 16/250AV Normally Closed 80C, manual rest stat but the base has a smooth shape that allows it to fit flush into the incoming air flow.
However, I have found many that will fit but they all have a base which will not fit flush in the hole, although the stat will fit in my MCHR unit as the bracket dimensions are the same.
The second photo is a typical example of what I have found on the net.
First question; why does all my Google searching only find stats that look like that second photo? Cannot find anything that resembles my current stat base. As the second will fit but the face will not protrude into the air flow, am I likely to encounter any difficulties?
Secondly, it appears that the most common stat is 10/250AC but my current is 16/250AC. What happens if I fit a 10/250AC?
Third photo is the current stat. Where can I find a stat like the existing one?
Thanks and toodle pip
Rex
Rex
