Screwing into exterior insulation
It will be difficult to get resin into a hole in the brickwork, through 120mm of insulation.
Resin and threaded rods. I recently used
to fix
to my walls.
You can get threaded in thicker diameter if you need a stronger support.
That tube of resin was enough to fix four threaded rods, two other things I needed to fix in a wall, to fill a few holes I saw and there was some (fifth of the tube?) left over.
Sure but that doesn't overcome the actual problem, which is that there's 120mm of (relatively) soft insulation between his proposed timber batten and the solid surface of the wall. Even if you could get the resin through the insulation into the masonry.
I think I'd be inclined to dig out some holes in the insulation and use a block of timber as a spacer, then foam up around the spacer and finish with some sealant. If you're clever you can ensure the holes you make in the render are smaller than the new batten, so it would all be hidden afterwards.
If we're talking about the staandard retrofit external insulation it's around 120mm thick, I can't see how those corefix fixings could ever work.
Thanks I didn't know that.
I was thinking of the stuff that I have recently seen being applied in west london. That stuff looks looks like is is about 20mm.
Perhaps the OP needs to drill a small hole to find out.
Why do you think that?
I think @JohnD is making a reference to the length of the nozzle.
Assuming that you drill 70mm in to the blockwork and have 110mm insulation, you would need a nozzle that is at least 200mm long. At a guess I would say that the standard nozzle is only about 140-150mm long
Drill (cut?) hole through insulation, drill hole in brickwork, clean out hole in brickwork, insert nozzle and pump resin into hole. Doesn't sound hard to me.
You would guess wrong. ;) Look at the picture, it is almost as long as the cartridge, unlike, say, a mastic nozzle.
They say they are 215mm
which is true to the very end of the nozzle, but they also sell 250mm ones
The hole in the brickwork is only 2mm wider than the rod so you don't need a massive amount of resin, hence the nozzle does not need to start at the back of that hole.
Sure but as mentioned yet again the problem the OP is facing is achieving a solid fixing at the outer face of the insulation not how you fix into the masonry.
Fair play.
I guess I should have Googled the dimensions first.
BTW, thanks for the link to the longer nozzles. From time to time I have to drill helifix bars in to external masonry fittings, the longer nozzles will be useful.
I don't understand what point you are trying to make.
I can't see how you will ever get a solid fixing with anything attached to the face of the insulation, only with something attached to the masonry. Hence @opps suggested using Corefix.
If you have to attach to the masonry (and I can't see any alternative to that) and there is c. 120mm of insulation that whatever method is used has to involve something well over 120mm long, partly in the masonry and partly above the surface of the insulation.
AFAIUI that is exactly what you suggested
except your suggestion was to use blocks of wood attached to the masonry rather than steel rods.
I can't see how you will ever get a solid fixing with anything attached to the face of the insulation.
You have to use a solid spacer that ensures his batten cannot flex, anything fixed to long studs alone will flex, hence the need for a solid spacer.
Well any batten will flex to some amount and I don't see why a few bits of wood will be significantly more rigid than the same number of steel rods.
I have given the OP an option, it is up to him what he does.
triangulation. the steel has alot of bending moment especilly at the face of the brickwork, whereas the block of wood will spread that across the surrounding area.a
Wood itself is not as strong but the shape of the support is important.
