Dishwasher Socket
30 Oct 2003
Worcestershire
I have just removed our old dishwasher (to be replaced with a new machine) and found the plug stuck to the back - similar to this thread
I could change to a flex outlet but space is a bit tight to get at the back of the machine to connect up. What is the latest thinking on putting a socket under the sink? I can either extend from the existing socket, or possibly pull a new cable to the SFCU above the worktop. The cable could be clipped directly to the surface
I could fit a flex outlet to a trailing socket under a cabinet which would be easier. Thoughts on this appreciated. I am not keen on the idea
Perfectly acceptable to fit a socket under the sink if it's the easiest solution
Mine is under the sink.
