Why do you think that?It will be difficult to get resin into a hole in the brickwork, through 120mm of insulation.
I haven't yet, that's why I'm here, I've never had this type of external insulation to worry about.How do you plan to do it?
Sure but that doesn't overcome the actual problem, which is that there's 120mm of (relatively) soft insulation between his proposed timber batten and the solid surface of the wall. Even if you could get the resin through the insulation into the masonry.Resin and threaded rods. I recently used
to fix![]()
Rawlplug R-KEM II Styrene-Free Polyester Resin 300ml - Screwfix
Order online at Screwfix.com. Low odour bonded anchor suitable for solid and hollow substrates. Suitable for repetitive use in confined spaces and can be used in water-filled holes (except sea water). For use with standard silicone gun. Supplied with 2 x nozzles. FREE next day delivery...www.screwfix.com
to my walls.![]()
Easyfix BZP Steel Threaded Rods M6 x 300mm 5 Pack - Screwfix
Order online at Screwfix.com. Steel. BZP. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
You can get threaded in thicker diameter if you need a stronger support.
That tube of resin was enough to fix four threaded rods, two other things I needed to fix in a wall, to fill a few holes I saw and there was some (fifth of the tube?) left over.
If we're talking about the staandard retrofit external insulation it's around 120mm thick, I can't see how those corefix fixings could ever work.
Drill (cut?) hole through insulation, drill hole in brickwork, clean out hole in brickwork, insert nozzle and pump resin into hole. Doesn't sound hard to me.which is that there's 120mm of (relatively) soft insulation between his proposed timber batten and the solid surface of the wall. Even if you could get the resin through the insulation into the masonry.
You would guess wrong.At a guess I would say that the standard nozzle is only about 140-150mm long
Sure but as mentioned yet again the problem the OP is facing is achieving a solid fixing at the outer face of the insulation not how you fix into the masonry.Drill (cut?) hole through insulation, drill hole in brickwork, clean out hole in brickwork, insert nozzle and pump resin into hole. Doesn't sound hard to me.
You would guess wrong.Look at the picture, it is almost as long as the cartridge, unlike, say, a mastic nozzle.
They say they are 215mm
which is true to the very end of the nozzle, but they also sell 250mm ones![]()
Rawlplug Mixer Nozzles 215mm 10 Pack - Screwfix
Order online at Screwfix.com. Additional mixer nozzles to be used with R KER II. For use in a wide range of fastening applications in concrete and solid masonry structures. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Rawlplug Mixer Nozzles 250mm 10 Pack - Screwfix
The hole in the brickwork is only 2mm wider than the rod so you don't need a massive amount of resin, hence the nozzle does not need to start at the back of that hole.
I don't understand what point you are trying to make.Sure but as mentioned yet again the problem the OP is facing is achieving a solid fixing at the outer face of the insulation not how you fix into the masonry.
www.diynot.com
You have to use a solid spacer that ensures his batten cannot flex, anything fixed to long studs alone will flex, hence the need for a solid spacer.I don't understand what point you are trying to make.
I can't see how you will ever get a solid fixing with anything attached to the face of the insulation.
Well any batten will flex to some amount and I don't see why a few bits of wood will be significantly more rigid than the same number of steel rods.You have to use a solid spacer that ensures his batten cannot flex, anything fixed to long studs alone will flex, hence the need for a solid spacer.
triangulation. the steel has alot of bending moment especilly at the face of the brickwork, whereas the block of wood will spread that across the surrounding area.aWell any batten will flex to some amount and I don't see why a few bits of wood will be significantly more rigid than the same number of steel rods.
I have given the OP an option, it is up to him what he does.
