4 people, one bathroom and shower and one WCHow many people live in your house, and how many bathrooms/showers/WCs are there?
Just a two floor three bed house with one bathroom and one WC. 7 radiators in total. Would like to go combi as the cylinder is a little dodgy, expecting combi boiler to use less energy and would like to get the space freed up from removing the cylinder.If you’re just changing the boiler, the only new pipes would be to get a cold feed to it, a hot outlet to join existing, and probably a gas pipe upgrade. It’s known as a conversion in the industry. Can I ask why you’re considering a combi boiler? Have you considered if it’ll cope with demands? Eg, how many hot outlets could be run simultaneously? Do you have sufficient water pressure and flow rates?
A modern boiler is more efficient than an old boiler, but combis are not more efficient than system or regular boilers.
Not necessarily, it all depends on pressure and flow rates.With only one bathroom, a combi will work OK. It will be somewhat slow to fill a bath.
What also need to be a factor a lot seem to forget is a combi will only heat the water on demand from the incoming cold main temperature, so colder water incoming in winter, which usually = less hot delivery than summer, when the incoming cold main is usually warmer.
And as you say, will be worse in winter.
I have an old, relatively small, combi in a large house and don't have any problems. Get what works best for you.4 people, one bathroom and shower and one WC
