An RCD without a neutral connection cannot possibly work, so I suggest you 'look harder'?Hi
I’ve just purchased a waterproof rcd for my shed. There is no neutral bar and no earth. I can understand there being no earth but what am I supposed to do with the neutral wires?
If what we can see were all there is (by way of terminals) it would make absolutely no sense. As I implied before, to function as an RCD, it simply must have four terminals - L & N 'in' and L& N 'out'.You'll need a multimeter to determine for certain what does what- it is likely that the terminal above the TEST button is N, the bottom 2 small terminals might both be N or might not. Are there any markings on the cable entry faces?
AhAre you realising that this is one piece?
It does look like that and, although I do not find the diagram on it very clear, it looks as if that probably confirms that it is only SP.Plus - does the C40 mean it is in fact a (single pole???) RCBO?
What you have indicated and say above seems credible (and different what what I had suspected).The unmarked terminal is an internal connection.
