Agreed.Or forget about electric showers completely and have 2x from whatever hot water system they already have.
A 60A fuse is dubious even for 1 electric shower.
If you have an 80A cutout then you might well be OK with one electric shower. You`d perhaps often get away with 2 showers dependant upon use/timing. 100A probably more so. Everybody having a shower on Xmas day just after the electric oven has been started might just be a bit more challenging especially if modern children (say 4 of them and their pals have stopped over too) , grandma and the inlaws have visited and the washer has started its second full cycle and the dryer on its first. Sensible people might make sensible timings to reduce a bit the times of greatest demands but a lot won`t. Simple load shedding of some time could just save the day in some instances.
A small guest house with ten rooms each with a 10KW electric shower fed on one fuseway to a big 6ft dial on the living room floor with selector of 1 to 10 determining which shower terminals are energised at that moment, all controlled by the landlord/landlady might be a solution.
An electro-mechanical solution or a shower priority switch or 7 or an app controlled thingy might offer slightly better solutions
