Well, exposed-c-ps are such because they are exposed and might become live because of loose connections or other faults.
Fair enough, but I still don't understand what that has got to do with SWA armour, since there are no connections within the cable that could 'become loose'.Well, exposed-c-ps are such because they are exposed and might become live because of loose connections or other faults.
Well, as I said, so long as the outer sheath is intact, the armour is not 'exposed', so it can't possibly qualify as an 'exposed-c-p'!So, in your opinion, it is absolutely impossible for any one to install SWA in such a way that the armour would be classed as an exposed-c-p
I don't see why glands need to be accessible, after all, couplers on galv conduit don't need to be accessible, so what's the difference?The glands will need to be accessible (I think)
For inspection purposes, I'll admit maybe not in this case as its 3 core.I don't see why glands need to be accessible, after all, couplers on galv conduit don't need to be accessible, so what's the difference?
That may be your view but, as you've seen, there is scope for debate.Steel wire armour needs earthing, weather the outer sheath is damaged or not.
Even if the outer sheath gets damaged, there are still two layers of insulating material between the armour than anything live - which is no different from the millions of Class II items out there.What if it gets damaged you gonna pop back and earth it?
I've previously covered that. Since the armour of the OP's cable has been 'stripped well back', he's not going to be able too use a metal gland in a matter that results in it being in continuity with the armour. As for 'need to be accessible', that does not necessarily mean 'touchable#. The terminals of electrical accessories are required to be accessible (for inspection and testing) but certainly aren't allowed to be touchable (without unscrewing the face plate/cover).Then if you decided to fit the correct swa glands they would need to be accessible.
It's 'unnecessary' for the job, but I still don't really see a problem in having (unearthed) steel armour in a cable that would be acceptable and safely 'touchable' even without the armour.Basically it's the wrong cable for the job
If the coffee table had live cables running inside it would be the same and it would be earthed.My wife was doing some vacuuming this afternoon. At one point, the cable of her machine came in contact with a (not earthedmetal coffee table. Is that any different from what we are talking about?
What's the difference between live conductors within the coffee table and live conductors within a cable which is lying on the coffe table?If the coffee table had live cables running inside it would be the same and it would be earthed.
It's not a matter of 'how I do things'. As I've implied, I would not install SWA 'unnecessarily'. However, if someone has installed SWA in such a way that the armour is 'cut back' and can neither be touched nor come into contact with body of any metal gland, then I would day that one could regard the cable as not having armour.You do things your way and I'll do them properly (wink face)
Probably not as old as me.... (wink face) cant work out how to do an emoji, I'm so old lol.
People who make metal coffee tables don't expect them to come live, people who make light up coffee tables do and so earth them, that's the differenceWhat's the difference between live conductors within the coffee table and live conductors within a cable which is lying on the coffe table?
I think you're probably missing the point - or, perhaps, trying to imagine a non-existent difference between things which are deliberately or accidentally 'associated with electricity'.People who make metal coffee tables don't expect them to come live, people who make light up coffee tables do and so earth them, that's the difference
I do get the point even if it's gone off track a bit.I think you're probably missing the point - or, perhaps, trying to imagine a non-existent difference between things which are deliberately or accidentally 'associated with electricity'.
If a touchable metal object is 'two layers of insulation away from an electrically live conductor', it doesn't make of jot of difference whether or not the object was 'intended' to have anything to do with electricity.
Fair enoughI do get the point even if it's gone off track a bit.
... because if SWA is being used because it needs to be SWA, then the armour MUST be earthed.So why do we get an earth ring (banjo) in a pack of glands if the steel doesn't need to be earthed, this is news to me but good news as my job just got easier.
Fair enough John I don't disagree but its not something I would do.Fair enough
As we are agreed, in the OP's case, there is no need for it to be SWA, hence no need to have earthed armour.
