Hi all
Read around some threads but no one’s wall seems to be out as much as mine and they’re all tiling onto plaster.
Method I’ve got:
Stripped walls back to bare studs
I’m putting nomoreply 10mm backer boards on the walls and then tiling onto these.
As you look at one wall, the top of it is 20mm further back than the bottom. Like it’s leaning away from you at the top. Given backer boards need to be glued all along the stud I’m a bit nervous about how I level it out. If I had a table saw I’d just cut some tapered strips out. But unfortunately it’s the one tool I don’t have. I’ve got a track saw but it’s going to be pretty tricky doing it on there.
Wondering if anyone had any ideas on how to solve?
Many thanks
Method I’ve got:
Many thanks
