Discussion/advice...
When I bought my house, I owned an 18" Bosh electric mower - it had been over-kill for the garden at my rental... but it seemed a bit puny for the larger garden where I moved.
One evening, in the summer, after toiling with the electric Bosch mower... I opened a bottle of wine, and browsed Ebay. In my infinite wisdom, I bought a second hand ride-on mower... with a questionable clutch declared. I thought, numbed by good wine, "I managed to change the clutch on my first car - a lawnmower can't be more difficult/expensive than that - can it?" Then I had a vision of modifying this ride-on mower... by adding Knight-Rider lights.... and, because it was cheap, I failed to resist the stupid urge to buy it.
Once I got it transported home - the clutch failed immediately. Then I found that I couldn't find anyone to service/repair it... or find a cost-effective clutch to replace it with myself. During "lockdown" I did some research and found I could refurbish the clutch using a particular adhesive and a cheaply available after-market clutch surface. I managed to refurbish the clutch - but, in doing so, noticed the deck needed refurbishment.... so did that - stripping back all the paint then using a layer of Red Led followed by Hammerite... but... once the world started to function again... I no-longer had spare time to put it all back together... and it has languished in parts ever since. Perhaps - in a decade or two - when I'm retired - I'll achieve my dream of mowing my law while pretending to be Michael Knight... but, until then, I need to be a bit more practical.
The ride on mower was a spectacularly stupid idea from the outset... my bigger garden is only just big enough for it to make sense to ride around mowing... but it is big enough to be a real pain to cut with a corded electric... especially as my available time is limited and sporadic... so, often, the grass is long when I get around to cutting it. I settled for using my corded Electric Bosch - which was an acceptable compromise for a while. It now cuts for about 15 minutes - then sequels like a pig and makes burning smells... cutting the whole lawn takes me about 4 hours - excluding breaks. I don't think it's going to last until I've refurbished my ride-on mower.
I've noticed others, with similar sized gardens, seem to prefer "propelled petrol" mowers... they walk behind them (rather than ride-on). I've never used a petrol mower - propelled or otherwise. Any ideas/advice from old hands?
One of my concerns is that my lawn is 'lumpy'... so any mower I buy (without consuming wine, and throwing common-sense to the wind first) would need to cope with non-flat lawns... My grass definitely resembles "the rough" more than "the green" from a golf course. I might fix that some day - but it won't be any day soon. A friend recently splashed out and bought a high-spec autonomous rechargeable self-driving lawnmower... I envy him for having a robot doing his chores... but don't think they work properly yet... and they're prohibitively expensive today. Perhaps in a decade I will be able to buy a cost-effective robot to do it for me.
Back to sensible: I've found these candidates for self-propelled petrol mowers:
hyundaipowerequipment.co.uk
www.toolstation.com
www.toolstation.com
www.moleonline.com
What should I be looking for? The price difference between 18" and 21" cutting widths seems high to me... I'd prefer minimum effort to complete a mow - but the 21" Fox mower is £90 (37%) more than the 18" - but only seems to offer 17% wider cut. To me, that makes the top-of-the-range seem much worse value. I've not got good intuition about which brands are 'worth more' - but I assume some are. Is my intuition that the Hyundai will be more robust that the Hawksmoor or Fox mowers a good one? Are there other brands I should consider?
P1 Hyundai Powered 51cm / 20" Petrol Electric Start Lawnmower | P5100SPE
The P5100SPE is a 196cc self-propelled petrol lawn mower from P1PE (Position One Power Equipment). Suited for medium to large lawns, the P5100SPE is the ideal solution for gardeners whose lawn is on a slope. Available now.
Hyundai 20"/51cm 196cc Self-Propelled Petrol Lawnmower | HYM510SP
The Hyundai HYM510SP lawnmower features a large 510mm cutting with and 6 different cutting heights from 25 to 75mm. With mulching, rear and side discharge this lawnmower is suitable for most garden sizes. Available now.
Hawksmoor 125cc 46cm Briggs & Stratton Self Propelled Petrol Lawnmower
Get a garden to be proud of all summer long by cutting your grass with this Hawksmoor petrol lawnmower. Powered by a 125cc Briggs & Stratton 4-stroke engine, the mower’s self-propelled rear wheel drive does the hard work for you – it’s easier to push and manoeuvre, making light work of larger...
Hawksmoor 166cc 53cm Honda Self Propelled Petrol Lawnmower
Take all the hassle out of cutting your grass by using this high-spec petrol lawnmower from Hawksmoor. Powered by a robust and reliable Honda 166cc 4-stroke engine, this mower comfortably tackles larger lawns with the minimum of effort.With a choice of seven cutting heights from 25-75mm, it's...
Webb Lawnmower Supreme Self-Propelled 46cm
MoleOnline.com is the new website of Mole Valley Farmers the Agricultural Supplies and Equipment Merchants
