How much should a Block Drive cost?
1 Jul 2011
West Midlands
Just had two quotes to upgrade my driveway (98m2) and to the untrained eye they both appear to be similar except for the price.
My question; is one too high or one too low, and what would the typical price per m2 for this type of work?
Quote 1;
Groundworks
  • Dig out area.
  • Test for soft areas and dig where necessary.
  • Stone areas with hardcore and compact.
  • Lay wash sand and compact.
Driveway
  • Screed area to required levels.
  • Lay required blocks
  • Compact and sand area to a level surface.
  • Install Channels and Natural Soak Away.
Price £8.8K
Quote 2;
  • Clear driveway to the required level.
  • Compact all foundations of the driveway with a 5 ton roller and whacker plate.
  • Install all Type 1 hardcore base to the required levels and depths and compact all hardcore with a 5 ton roller and whacker plate.
  • Install ACO drainage channels.
  • Lay permeable membrane on the driveway area and lay a sharp sand base to the driveway and machine compact.
  • Lay block paving to the driveway and machine compact into the sand base.
  • Sweep kiln dried sand into the joints of the blocks and sealant.
Price £6.5k
Thanks in advance.
I was quoted £90/sqm for similar to 1) a few years ago. North England
Quotes seem different (scope of works) to me; no digging on quote 2
This is the Midlands, therefore, quote 1 is in the correct ballpark.
The guy said he would excavate to the correct level for all the prescribed infill.
I paid £130/sqm last year (lancs.) for a top notch job - 150sqm. 26 tonnes MOT, 5 tonnes 5mm granite to dust (might have been more), marshalls driveset coppice. Took crew of 3 11days to dig out and lay. Included some accos and drainage work.
Clearly I’m going to have to legislate for a higher spend. The guy providing the lower quote has to be cutting corners.
Unhelpful
I have just paid around £130/SQM in Manchester for brindle block.
Did include some hedge removal, new step and tarmac work on the footpath.
Have you researched into the two companies?
Lot of dodgy driveway firms.
Those quotes just state operations and neither state specifications or material standards, so they could be quoting for completely different things and you would not know.
Obviously going to have to get more quotes.
Out of interest, I found the contractor for the lower quote on trusted traders. They had over 200 positive reviews, I must say I tend to treat some with suspicion.
The provider of the higher quote is a small local business (deals only in brick paving), been in the business since the late 1980’s, doesn’t advertise much and I have seen a lot of his work in the area.
Thanks for all the input.
Where in the Midlands are you?
