Hi people.
Bad experience with plumber.
I have a 15ltr hyco water heater which is leaking at the hot water connection.....1/2 inch BSP to 15mm.
Is this relatively easy to fix or do I have to call another plumber....more expense .Cheers
The original "plumber" turned out to be a cowboy.....i did all the checks that "Joe public " are advised to do. Unfortunately I was at work when he did the job.
