Hi all
I've got some lead work coming up and will need to chase the stone wall for the flashing. I'm planning to get an angle grinder and use a 10mm thick blade like this:
Or
(or the 125mm equivalents if I get a larger grinder).
My question is will a cordless angle grinder be powerful enough or am I better getting a corded model? If going cordless, my preference would be DeWalt 18V as I've some other gear of the same.
One other question.... If once I've cut the chase it isn't quite deep enough and I can't get deeper with the grinder and disc, could I use this inside the chase to make it a little deeper? Just to be clear, the chase will be a straight line (parallel to the roof below), and will be cut through both mortar (lime) and the stone itself, as the wall is random stone.
www.screwfix.com
Any help most appreciated.
Cheers
Or
Mortar Rake 8mm x 40mm - Screwfix
Order online at Screwfix.com. For raking out mortar using an angle grinder prior to pointing. FREE next day delivery available, free collection in 1 minute.
Cheers
