Are there any special tools for replacing spalled bricks, especially, to avoid filling the cavity.
Cheers, Camerart
Hi,Buy yourself a nice masonry blade for your reciprocating saw, drill a few holes to get the blade in and just cut around - it won't cut brick but it'll go through the mortar easily enough. For replacing bricks I always shove some cavity insulation in first to stop the mortar spilling out the back.
Hi J,I second the recip saw. With the right blade, works a treat.
Hi J,![]()
Bosch EXPERT Brick Carbide Sabre Saw Blade
• Carbide teeth, designed for cutting highly abrasive mineral-based materials. • Large tooth pitch (12.7 mm) for rapid cutting• Wide body (23mm) and extra-thick gauge material (1.5mm) for stabilityThe blade features a carbide tooth strip, which is welded on a highly elastic carbon steel body...www.toolstation.com
Hi J,For a one off job, get the cheapest - or at least cheaper end. Check the saw to be 100% sure but I think all the blades will fit all the saws.
Hi J,![]()
