I'm at a loss. Got someone to lever upwards under the tyre with both wheels off the ground. Couldn't see, feel or hear anything. But this is usually the case with either the problem wheel or both wheels off the ground - the problem disappears.
With both wheels on the ground I got him to hold the tyre at 12 o'clock and rock it inwards and outwards. The movement and knocking is obvious, but not low down where the bottom ball joint is. And it's not the AR bar link either. Feels like it's coming somewhere from the hub area but I can't pinpoint. Checked the two bolts holding bottom of strut to hub are tight - and they were.
I can get the same movement/rattle if grab the lowest coils of the spring above wheel and move it in towards engine then outwards. Can feel the knocking near the bottom of strut near hub rather than top of it.
If not the lower ball joint, what else could it be? Wheel bearing? My experience of these is the whine or rumble. Can bad bearing clunk when driving along and cause rattling/movement when moving wheel in and out at top by wheel?
What other things are possible? CV joint?
