I never use those hard plastic boots, nightmare to keep secure.
Well worth getting it on a ramp and let an experienced eye have a look
It's generally the bearing part that fails but you never really know until its all off to inspect it. But generally the bearing will be noisy so if no noise it's likely its the rubber.I have a diagnosis - at least a most likely cause diagnosis. Not an easy one this. Took it to my usual MOT centre and they put it on the MOT ramps and gave the front wheels a workout with the shaker. Then lots of looking, rattling wheel/spring, levering, look under bonnet. Then more levering and another go on the shaker. Definitely not ball joint (no movement in it), AR bar or bushes. Was in there 20 mins.
Said it's feels like it's high up, so most likely top strut mount. I realise it's a difficult thing to positively identify, due to location/access. Think it was a process of elimination.
If the strut mount, is it ok to drive and do they fail, causing death and destruction? Or just do it ASAP?
What do I replace? Just the bearing, or the big metal plate that holds it all together - or both?
FYI - the spring on strut is 18 months old, but rest of strut is original - 19 years old/108,000 miles.
ROLLING BEARING, SUSPENSION STRUT SUPPORT MOUNTING LEMFÖRDER 31419 01 FRONT AXLE | eBay UK
LEMFÖRDER 31419. Fitting Position Front Axle. Quantity per axle 2. Fitting Position Left and right. PART NO31419 01. Are you sure that this part will fit Your vehicle?. If any doubts, just send us your vehicle identification number (VIN) and our highly qualified advisors will check and confirm!www.ebay.co.uk
Not fully true. No specific area of test, but comes under suspension mounting/bush.Strut top bearings, are not part of the MOT. A failing bearing is not a reason for MOT failure.
| (c) A shock absorber bush excessively worn | Major |
| (a) A spring: (i) insecurely attached to chassis or axle (ii) with fixings loose to the extent that relative movement is visible | Major Dangerous |
It does have to be bad and excessive to warrant a fail though
He could also fail it under a manually raised fault ( not specifically covered in the manual) and label it as Dangerous to drive if he felt it was that bad.Not what my inspector told me, and my bearing was really bad..
No.No drama at all, they are very progressive and the worst that can happen is the steering feel becomes clunky.
No.
They can totally fail and detach and be dangerous.
Yes. And had 2 struts totally fall out the housing, allowing 1 wheel to lean out at around 45%.Have you ever changed changed such a bearing? I have...
The strut centre bolt also has to fail, and/or the three turret bolts too, for the strut top to detach..
Not true sorryThe strut centre bolt also has to fail, and/or the three turret bolts too, for the strut top to detach..
Not true sorry
I'm only a mechanic and mot tester so yes we will have to disagreeWe will have to agree to disagree, because the only way they can fail dangerously and catastrophically, is for the top of the strut to force its way through the top of the turret/inner wing.
